    I have a OTG cable with a usb micro pass through with a USB Female input.
    I can definitley plug in the mouse and use that, but the micro usb pass through seems to NEVER pass through power.
    It's a cheap Chinese cable.
    So I'm wondering if anyone has ever successfully charged the tablet AND use peripherals at the same time?
    10-14-2015 05:26 PM
  2. tbsteph's Avatar
    Nope. Would be interested if someone has a solution.
    10-18-2015 06:56 PM
  3. nordnord's Avatar
    Look for the post where they discuss periphs that sometimes work with the Stream.
    I bought a few and found one that seems (I'm still studying it) to work well. It is the nekmit power plug with 2 regular sized USB connectors and a Y split 2 usb cables on one end and a mini usb connector on the other end. The cable is fairly long. I totally ditched the cheap charger that HP provided... it is not strong enough to charge anything other than the tablet itself. The second you try to put in a hub (I use the little belkin 4 port), you start losing battery power.
    Too early to say for sure, but would be curious if anyone else has tried this. Right now, I have an external USB stick for backup of data plugged in along with a USB 2 flexible keyboard and a usb gigaware portable mouse.
    11-24-2015 09:43 AM
  4. Groover1971's Avatar
    I don't have the Stream 7 anymore but when I did, I watched a YouTube video and showed what to get. I bought the cables and hub and it actually worked. The problem was that it was a slower charge and the charging indication on the battery icon wouldn't show that it was charging, even though the charge would slowly increase. Initially, I had a USB mouse and keyboard connected to the hub and used Miracast to project to my TV. It worked great but I didn't want to have all of those cables laying around all of the time. You may have to switch the power (red) and data (black) connectors on the Startech Y-cable. In the video, he shows that it is charging using an amp meter since the indication doesn't show. He also didn't use a USB hub because he was using Bluetooth. The link for the video is below.
    03-24-2017 09:09 PM
  5. Cristoby's Avatar
    I have tried with the Dell-branded OTG adapter for the Dell Venue 8 Pro, but I assumed it did charge because I did not see the charging icon. I'll try again.
    08-02-2017 10:56 AM
  1. How do I send a large file using OneDrive?
    By David Mundstock in forum OneDrive
    Last Post: 10-15-2015, 01:10 PM
  2. Should I jump ship and get an icon?
    By mike208 in forum Nokia Lumia Icon
    Last Post: 10-14-2015, 05:46 PM
  3. Why do I get an error message when I click on wifi?
    By Windows Central Question in forum General Phone Discussion
    Last Post: 10-14-2015, 04:49 PM
  4. Microsoft confirms it has no plans to make first-party cases for Lumia 950 or 950 XL
    Last Post: 10-14-2015, 04:42 PM
  5. Lumia ReFocus app updated to remove online sharing feature
    Last Post: 10-14-2015, 04:30 PM
