1. radddogg's Avatar
    There is finally a fix for the low memory problem on HTC Windows Phone 8S.
    It is called Update 3. I just installed Update 3 or GDR3 as it was originally known and as well as better categorisation of storage there is now at last an option to delete the temporary files!
    To install first go HERE to register as a 'developer' (click the Start Building button)
    Then go HERE to download the updater.
    Finally find the Preview for Developers app in your apps list and follow the instructions to update.
    You may need to clear some space to update but when you do update you will not lose any data.
    Hope this helps someone!
    11-04-2013 11:27 AM
  2. Chris Nguyen1's Avatar
    THX SO MUCH!!!! Finally got my space back ^_^
    was planning on getting a new phone...but now im gunna stay with it hehe
    11-05-2013 08:24 PM
  3. adriantalpas's Avatar
    radddogg, did u updated to GDR3?
    I'm curious about this!
    11-08-2013 02:06 AM
  4. adriantalpas's Avatar
    I updated my device, and its working fine. No problems so far.
    Sent from my Windows Phone 8S by HTC using Tapatalk
    11-09-2013 02:36 PM
  5. mixa8x's Avatar
    whether 8s get regular gdr3 updates ?
    11-10-2013 05:01 AM
  6. index1366's Avatar
    It will get the GDR3 without any problems when it is released officially, don't worry.
    11-15-2013 11:06 AM
  7. mixa8x's Avatar
    I've got it an hour ago....
    11-15-2013 02:22 PM
  8. SoullessOnyx's Avatar
    You're all acting as if you have like Gigabytes of free space, I literally have 400MB after Update 3...
    12-15-2013 08:11 PM
  1. What do you guys use for an antivirus?
    By janktastic in forum Dell Venue 8 Pro
    Last Post: 12-31-2013, 09:25 PM
  2. Why does WP 8 need a file explorer?
    By Aardappelboom in forum Windows Phone 8
    Last Post: 11-07-2013, 11:25 PM
  3. Student discount on surface pro 2
    By Sheraz Ahmad in forum Microsoft Surface Pro 2
    Last Post: 11-04-2013, 01:22 PM
  4. Skype drops its API for a new improved one but...
    By Cienight in forum Windows Phone 7
    Last Post: 11-04-2013, 10:19 AM
  5. do you have any lag or freezes on your 820 ?
    By stalemate1 in forum Nokia Lumia 820
    Last Post: 11-04-2013, 10:15 AM
