1. akulgupta100's Avatar
    Since the past 2 days I'm having severe battery issues...
    Charging takes all eternity and it is all drained in 5hours max.
    I'm so fed up of this
    I tried
    >Soft reset
    >Full discharge and charge again
    Also
    Phone becomes a furnace while charging
    NFC and GPS are off
    Any suggestions?
    Also a reboot causes drastic battery level changes
    Before reboot battery was 50% and 99% after reboot
    And while charging , i have observed the charging led alternatively flashing red and green
    Thanks in Advance
    Sent from my Windows Phone 8X by HTC using Tapatalk
    12-12-2013 03:05 PM
  2. WPmunkey's Avatar
    Reset to factory defaults and see if the battery still drains. Then you know if it is hardware or software. Make sure you have backup on first
    12-12-2013 03:14 PM
  1. Nokia 1020 battery drain rates.. mine normal?
    By markm75 in forum Nokia Lumia 1020
    Last Post: 03-14-2014, 07:57 AM
  2. battery wear problems
    By muitosabao in forum Microsoft Surface Pro 2
    Last Post: 12-20-2013, 09:52 AM
  3. Replies: 3
    Last Post: 12-13-2013, 07:06 AM
  4. Battery on screen
    By Bogdan Ionut in forum Nokia Lumia 800
    Last Post: 12-12-2013, 09:26 AM
  5. Replies: 1
    Last Post: 12-12-2013, 03:55 AM
