Phone Lockup and Heat/Battery Drain - Tips If You Have This
sandmanfvr
129
Well was texting on my arrive, to like 2 or 3 people. Then the "click" sound as you type (get that in your mind) just went:
click click click click click click click click click click click click click click click click click click click click click click click click click click click click click click click click click click click click
The phone responded, just the sound was locked. I rebooted and left it alone, came back after a couple hours, phone was HOT and down to half power. Turn it off, pulled batter and let it cool. Popped battery back in, powered up and let it set for 5 minutes, cool as usual. SO I learned Windows Phone lock ups are not always cleared from the processor/memory unless you do a battery pull, as with android a power off is just that, full power down.
Glitches happen and not down on Windows Phone or the Arrive, but a tip to others: if you get a glitch or lock up, PULL THE BATTERY and you should be fine.
Tallgeeselll05
