Problem with Mail and Calendar app draining battery in background
I am using L640 with W10M .164 build and I'm quite happy with it. This morning, when I opened "battery use" in "battery saver" I noticed that Mail and Calendar app drained aproximatley 45% of the battery, almost all of that as a background process. Later I contacted my friend who has L830 on the same build and same app is on top of his battery draining list, also as a background process. My questions are:
-I doubt that is normal, so what should I do to decrese this abnormal background battery usage of the app?
-If I just turn off ability to work in background for Mail and Calendar, is there any negative consequences beside need to manualy sync mail?
Thanks in advance!
Thanks in advance!
