Shop HP’s Memorial Day Sale:Save up to 61% on PCs and more!
  1. kiteless's Avatar
    Edit: (THIS IS RESOLVED, SEE BELOW)
    Hey all so I have been searching around and not seeing anyone else with this problem. Really enjoying my Lumia 950 XL but I can no longer update it because the phone storage is effectively full. "System & reserved" is claiming 25.4GB of space. I have the phone setup to install apps on the phones internal storage and everything else goes to the 64GB SD card. I have not been able to find a way to clean up this huge amount of space being taken up by this. I would REALLY prefer not to wipe and reset my phone. Anyone else seeing this and/or know a fix for it? Thanks.
    jamrock60 likes this.
    12-26-2015 11:06 PM
  2. jamrock60's Avatar
    This is a new one. You might have to do a reset. Seems like there are allot of dump files.
    12-26-2015 11:29 PM
  3. kiteless's Avatar
    Thanks for the info. I might have to do that. I mainly don't want to reset because I have a game save I don't wanna loose. :)
    Wish there was a way to clean this up without wiping the phone.
    12-27-2015 04:50 PM
  4. atrsh's Avatar
    Can you just move the game apps to the SD card and then do the reset?
    12-27-2015 06:34 PM
  5. ronaldme's Avatar
    Sadly there isn't a way to do a hard reset without losing apps, even moving apps/games to sd card ms won't work.
    Do a hard reset with buttons.
    12-27-2015 08:55 PM
  6. anthonyng's Avatar
    Wow what's in there? Mine says 3.99 is for system files for windows and another 256meg for virtual memory totalling 4.24gb
    12-28-2015 02:22 AM
  7. kiteless's Avatar
    SOLVED: Hey all so I figured it out. I finally started really tinkering around. In the summary it said thatI had like 2.4GB of apps installed in phone storage so I kept ignoring that section, but when I went in there I noticed that Spotify was using almost 17GB of space, and this YouTube downloader app was using like 4GB of space. For some reason these didn't count against installed app space usage. So I told the phone to move the app to the fast 64GB SD card. Spotify took a little while, but the space taken up didn't change. I then moved the YouTube downloader app to the SD card as well. I guess after that finished the storage meters caught up. I suddenly had around 19GB of free space on the phones built in storage! Yay. After that I was able to install the latest updates.
    This leaves me wondering why it would label the downloaded content of these two apps, and likely others, as System and Reserved space. I don't recall Windows Phone ever behaving this way in the past.
    Well hopefully this will help out other people. Thanks for all the feedback folks!
    // Jason
    Captain_Eric and anthonyng like this.
    12-30-2015 05:28 PM
  8. snakebitten's Avatar
    I mostly appreciate both the effort you made to find a solution, AND the integrity to post the facts here without just throwing a Microsoft Sucks temper tantrum. :)
    Refreshing. And informative. Good job man.
    12-30-2015 05:43 PM
  9. ronaldme's Avatar
    Because it is information stored in the isolated storage.
    12-30-2015 05:50 PM
  10. kiteless's Avatar
    Hey thanks for the Kudo's! I see too many posts that are exactly as you describe, or almost worse, they say. "Oh never mind I figured it out." And it's like... WHAT DID YOU DO?!?!?!?!!!!!111!!!111oneoneone So I thought a conclusion would be helpful. haha.
    Despite having a few flaws, as all phones do, I have had a great experience with my 950XL. It's by far the nicest phone I have ever owned, and the lagest.
    That's exactly what seems to be the most obvious answer. By why isolate it? When it's on the SD card, it shows up as regular storage and not "System and Reserved" on that location (SD).
    Windows, Mac, Linux, IOS, Android, I dabble with all of them, some of them professionally. They all do things that don't seem to make sense. Some worse than others. If this is done this way by design I think it's a bad choice. But it;s manageable if one knows where to look and what to do.
    Personally I think Microsoft is doing a good job trying to make Windows 10 Phone, as easy to use as possible without going "one button" iPhone simple.
    Anyway thanks for the replies folks.
    // Jason
    12-30-2015 06:25 PM
  1. Hdmi help me!!
    Last Post: 12-27-2015, 05:05 AM
  2. How i could take backup of Lumia 720 in my laptop.?
    By Windows Central Question in forum Nokia Lumia 720
    Last Post: 12-26-2015, 11:04 PM
  3. i am a Lumia 535 user . problem in installing apps manually
    By sourav77 in forum Microsoft Lumia 535
    Last Post: 12-26-2015, 10:55 PM
  4. swipe keyboard in Edge dysfunctional
    By brusbrother in forum Microsoft Lumia 640
    Last Post: 12-26-2015, 10:28 PM
  5. Microsoft Lumia 535 owners will receive w10 in January and February?
    By nikhil naik1 in forum Microsoft Lumia 535
    Last Post: 12-26-2015, 09:33 PM
