    2day old fone, I've turned Catana, skype, hello and one drive off, screen always on 10% and internet has been set on 3g. Full charge is very quick but within 20mins down to 88%, I just recharged fully again and it's down to 83% within 25mins. I've seen posts that a system update helps but I can't update as it sits on 0% update. I've completed 5 factory resets in 2 days. Pls help
    07-10-2016 05:29 AM
  2. mtiede's Avatar
    I'd maybe keep it plugged in and wait for that update to finish. I'm guessing all the battery use is in trying to download the update.
    Chintan Gohel likes this.
    07-10-2016 06:48 AM
  3. SL2's Avatar
    Get a new sim card. Old cards can make the phone use more power.
    Also, install the latest firmware.
    07-10-2016 07:20 AM
  4. Chintan Gohel's Avatar
    I've seen your other post on the many resets you've done.
    Use windows devi tool to do a fresh install.
    Once that is done, do not restore when setting up the account
    Disable auto updates of store apps
    Check for updates for OS but download and install when charging from wall socket with original charger
    Once all OS updates and firmware are installed, then install apps, a few at a time. Same with app updates
    07-10-2016 10:00 AM
  1. ONE DAY ONLY Surface 3 LTE Bundle on QVC $700
    By RumoredNow in forum Expired & Archived Deals
    Last Post: 07-13-2016, 05:38 PM
  2. How do I set up voice activation of Cortana on my Surface Pro?
    By Windows Central Question in forum Cortana
    Last Post: 07-10-2016, 04:28 PM
  3. Battery
    By kaktus1389 in forum Microsoft Lumia 640 XL
    Last Post: 07-10-2016, 09:15 AM
  4. Microsoft 950 download updates static?
    By Windows Central Question in forum Microsoft Lumia 950
    Last Post: 07-10-2016, 05:24 AM
  5. Replies: 1
    Last Post: 07-10-2016, 02:09 AM
