The Surface 2 is an ideal form factor for using a small USB DAC / Amp to listen to music while on the go. However, mine doesn't much like to multitask. The audio stream, though fine when the system isn't doing anything else, is prone to hiccups when listening while also browsing in IE, using twitter, or reading email. It's unfortunate. Anyway, is anyone else experiencing these symptoms? I wonder if this can be helped by a future system software update or if it's a matter of too slow a processor or too little memory?
FWIW, I've tested this with a Nuforce uDAC-2 and an HRT microStreamer. The problems is the same for both so I don't think the DAC/Amp is the problem. I have tried driver settings of 16/44.1 and 24/44.1 and that doesn't make any difference either. It does seem to be worse if I set to 24/96 (which is understandable). It's also the same whether I use Xbox Music or MediaMonkey.
Thanks to anyone who can share their experiences.
