This is more of a rant than seeking help. But advice is also welcomed.
How did Microsoft create such an amazing device, then mess up the charger connecting port!!!! Its so bad. I struggle with it every time, literally every time.
The charging light indicator seems like its on, but it doesn't seem to charge. It has a major design flow, as it has very high quality constraints that can be easily missed. Its known in design that's its not preferable to make two parts connect at two specific points that's called Over Constrained Design, it must always be, one specific point, and the other should be more of a loose end or a gap, as for if any production errors can be neglected! The way the connector is design with five 1mm pins meeting, in order to charge is insaaaane!
Design 101
To mess it up even more, they deigned it pins to pins, not pins to holes! :S
Design 101
