1. 3wm Tech's Avatar
    SO i was about to buy a SB2, but then started to investigate how the battery could be replaced down the line. Macs you take to apple/diy, dell you can open them up and replace them etc. But it seems MS dont offer any battery replacements. It also seems that the SB2 is not repairable for anything as everything is surrounded by glue and unserviceable ?!?!
    What are you all doing when you battery life goes bad in 24 months time? Getting new laptops? This seems insane to me for a 2500-3k machine?!
    07-18-2018 11:25 PM
  2. Golfdriver97's Avatar
    I honestly think it's dumb. I get that the manufacturer doesn't want to warranty repairs done outside of MS control, but at the same time, consumers should have the right to repair. It wouldn't surprise me if most of those components are proprietary, and difficult to get. I also wouldn't be surprised if some things are soldered in, like RAM and the SSD.
    07-19-2018 11:03 AM
  3. 3wm Tech's Avatar
    This says it all. I contacts MS and they seem to have no answers after the 1 yr warranty, ill try and speak to someone else, but this seems like a throw away product?
    07-19-2018 02:34 PM
  4. Golfdriver97's Avatar
    I was under the impression that a throwaway was the idea behind it.
    07-20-2018 03:19 PM
  1. Battery 1 stuck at 75% -- is this real?
    By DCW1000 in forum Microsoft Surface Book 2
    Last Post: 01-28-2019, 06:13 AM
  2. No settings to stop mousepad from working if mouse plugged in
    Last Post: 07-19-2018, 12:16 PM
  3. Dell XPS 15 vs. XPS 15 2-in-1: Which laptop is best for you?
    Last Post: 07-18-2018, 12:10 PM
  4. Chime in: Will USB-C ever totally replace USB-A?
    Last Post: 07-18-2018, 10:40 AM
  5. WebToApp for Windows review: Get picture-in-picture mode for any site
    Last Post: 07-18-2018, 10:10 AM
