1. arislgr's Avatar
    I mostly use the screen while detached, but it's battery life is quite short. Can I recharge it by attaching it, while on the road (not plugged into AC)
    11-03-2016 12:04 PM
  2. aalupatti's Avatar
    Nope. The batteries dont charge each other
    11-03-2016 12:20 PM
  3. orlbuckeye's Avatar
    You just have to use it with the screen flipped and base connected and you use both batteries. You can connect the power to the clipboard only. If you could find one of those external chargers people use for phones that has a plug that matches the surface it might work.
    xandros9 likes this.
    11-04-2016 09:38 AM
  4. worwig's Avatar
    Mike Gyver has some external battery products that they claim work. A bit pricey.
    MCT: Products: Surface, Macbook, Yoga, Dell Batteries and Car adapters Surface
    rdubmu likes this.
    11-04-2016 11:04 AM
  1. We can't set mobile hotspot. Turn off wifi
    Last Post: 11-07-2016, 12:33 PM
  2. Replies: 2
    Last Post: 11-03-2016, 03:23 PM
  3. Why can't I see and receive photos in viber?
    Last Post: 11-03-2016, 07:59 AM
  4. We can't set mobile hotspot. Turn off wifi
    Last Post: 11-03-2016, 07:29 AM
  5. Replies: 0
    Last Post: 11-03-2016, 02:41 AM
