1. Friday20's Avatar
    Hello everyone I'm using surface pro 5 now and usually I can get around 5 hours of battery life.
    I've done everything to improve the battery life and I install the battery bar.
    I discover that when my battery is above 50% ,discharge rate will be high like 20000mw or higher all the time no matter what am I doing and when the battery is below 50% ,discharge rate suddenly low like 2000mw or lower or higher up to task.
    I underclock the CPU maximum to 90% and set everything to low as possible in power option ,disable service ,background app ,update driver etc.
    I use windows 10 1903 build 18362.387
    i5 7300u 4gb
    I think the problem maybe the driver but which one ,that when its see my battery is above 50% its boost things up.
    09-30-2019 04:09 AM
  2. N_LaRUE's Avatar
    Double post
    10-02-2019 01:24 AM
  1. Build 18990.1 does not detect my external HDD anymore
    By The_GTA in forum Windows Insider Program
    Last Post: 10-02-2019, 05:15 PM
  2. If the name of my iphone isn't appearing on files, what do I do?
    Last Post: 09-30-2019, 08:00 AM
  3. Surface Book 2 avaliable on December 2019?
    Last Post: 09-30-2019, 07:56 AM
  4. Leaked marketing images show glimpses of Surface Pro 7, Surface Laptop 3
    Last Post: 09-30-2019, 02:50 AM
  5. Add Vantrue's N1 Pro Mini Dash Cam to your car and save $24
    Last Post: 09-29-2019, 12:00 PM
