Surface Pro 2 - Wake on Lan - WIFI
Hi all,
I've got a Surface Pro 2 that uses wifi to connect to my router and get internet accesss.
I've also got a Lumia 950 and I'd like to get Cortana to be able to turn on my PC remotely, this I believe is possible if I set the PC to use 'Wake On Lan'.
My question is this, does anyone know if the WIFI adapter in the Pro 2 supports WOL?
I had WOL working on an old desktop of mine a few years back but it had a network card and connected via Ethernet.
Any help would be appreciated.
Thanks,
Nic
Hi all,
Thanks,
Nic
