New Surface Pro Battery Life: i5 vs i7
Shrave
17
I'm looking to purchase the new Surface Pro. I've been debating between the i5 and the i7 models. Assuming a user performs the same tasks on both models, would the battery life be the same or would the i7 drain the battery faster as it is more powerful? Would bigger SSD sizes also drain batter faster? Again, I assume the user is performing the same tasks on both models.
JohnnyRedLight
127
The i7 also has Iris graphics. Not just for “gaming” but for smoother graphics all around. The battery life between an i7 and an i5 would be negligible unless you are possible doing something (rendering) that fully utilizes all cores and threads of the i7, but even then it shouldn’t be hugely more battery consumption. The size of your SSD will not affect the battery life.
If you have the budget and plan to keep this for several years, I would definitely recommend the i7.
Shrave
17
Thanks for the responses. I'm assuming the same is true for 8 GB vs 16 GB ram. More wouldn't make a difference in battery life, correct? It's all about what you are doing on it.
JohnnyRedLight
127
Hmm, this makes sense. Anyone else want to comment on this? If the fan kicks in, I'm assuming it uses more power, reducing battery faster. Is this significant.
The Fan itself doesn't use much but it does indicate that your CPU is using more power and needs to be cooled down. So technically yes, when the fan comes on you are using more juice.
onlysublime
1,077
of course if the fan kicks in, it's going to use more battery. moving parts always uses more energy.
but if you're comparing the exact same tasks, you're going to get the same battery life. however, because the i7 has more horsepower, the tasks that could use more power will definitely use more power and in the process use more battery.
it's like a car engine that can turn off cylinders. if you have a 4 cylinder economy car and a V6 that can turn off cylinders... at 30 mph, the V6 may only be running 4 cylinders and both will get the same mileage. but floor the gas and the 4 cylinder car may top off at 110 mph while the V6 can go up to 130 mph and use more gas in the process.
ajcletus500
209
I really would want to see the difference an i5 fanless and an i7 with a fan on the surface pro would make. Also power throttling is something of a concern
onlysublime
1,077
yeah, I wonder about throttling on a fanless design. I'm betting Microsoft is counting on the fact that people won't be using their new i5 Surface Pro to render video in Handbrake or anything that has sustained loads on the CPU/GPU. you have to be able to push the heat out. if you're only using bursts of high load in CPU/GPU jobs (and frankly, this is most computing jobs including Photoshop, programming editors, etc.), then fanless should be fine. But run the CPU/GPU at 100% for more than 5 continuous minutes, I wonder how fanless holds up.
L0n3N1nja
184
The I5 and I7 are both a dual core with hyperthreading, performance and power draw will be almost identical. The I7 has more power graphics that will draw more power if doing something graphics intense, so it would depend on the workload.
Either way both are 15W processors and the difference won't be very big.
astondg
409
Actually from what I've read more RAM can mean more power draw, even if it's not actively 'in-use'.
E.g. if a machine has 2x1GB RAM sticks it will use more power than 1x2GB stick. But with the Surface I think the RAM modules are soldered onto the motherboard? So I don't know exactly how that effects things but if there are more modules then there should be more power draw. If it's still the same number of modules, but denser modules, then maybe there won't be any extra (or negligible extra) power draw.
DJCBS
719
It really depends on what you do with it, yes. The i7 will in theory be faster and more efficient. But you won't really notice it unless you try to do something that REALLY pushes the hardware.
But think of it this way: if there's ANY chance you ever consider needing the power of the i7, go for it. For one very simple reason: if you use a core i5 to try and do the task of a core i7, it will do it...but it will require a lot more power and resources...which means you'll end up consuming more battery than you would if you had a stronger chipset. Same for RAM.
It's like you trying to pull a cart. If you're fat you'll have a harder time pushing it (core m3), if you have the normal average healthy human body you'll be able to pull it even if it requires a bit of effort (core i5), if you go to the gym and are a fit guy, you'll pull the cart way easier than any of the others (core i7).
onlysublime
1,077
I read somewhere that the new i5 was just as fast if not faster then the i7 in the Surface Pro 4.
I owned an i5 SP4 but later switched to the SP4 with i7 / 8 GB / 256 GB. The i7 has all the frequencies of the i5 but can scale even higher. Plus, the i7 comes with Iris graphics which is over twice the execution units of the regular Intel graphics. So for the CPU part, the Kaby Lake i5 is better than the Skylake i7 CPU. But the GPU is often more important so the i7 wins out.
infinihertz
The new i5 probably is comparable to the old i7, if that's what you care about. But the new i7 is faster still (I think the CPU is something like 15% faster than the new i5) and the GPU is way faster - roughly double the speed. If you will game or do graphics rendering or something and don't want to do that on a different, dedicated machine I think the i7 is very much worth it. But if you'll have more casual usage the i5 (or m3) is fine. As DJCBS said, if you'll be pushing the Surface hard, the i7 may actually get better battery life. If you won't push it, it'll be worse with the i7, but I don't know how much. I'm confident it's less than an hour, but whether it's almost an hour or 15min I can't say.
Wevenhuis
408
I have the exact same question. I posted a couple of questions in the comments for Matt and Daniel based on this article. Still have no response. Pending.
https://www.windowscentral.com/new-surface-pro-2017-microsofts-best-2-1-date-video
For battery saving tips, I found this video by Linus insightful.
https://www.youtube.com/watch?v=1z01hT2yy0g
Current online stories and forum posts on the intel I chipsets seem to suggest that for general purpose use the core i5 is the best bang for your buck in terms of balance cost and performance. i7 seems to be overkill. But if you need it you need it.
I've already read many stories and posts on the silent fan. I think in the beginning many fans will be ideally "silent" when new and fresh. It is my experience though that over time the fans become noisier. Not sure why but mechanical parts fatigue and dust over time due come to mind, no matter how tiny the vent slots are.
I agree with others that fans will consume some power. I don't know how much. But the fanless i5 design does make me curious and does provide food for thought about the impact of mechanical ventilation on battery perfomance on windows mobile tablet-pc devices. After all, why would they consider bringing this design to market?\
For me choosing between the M3, i5 or i7, I think the i5 is the most interesting propsitiion for general all-round use.
I agree that batterylife will likely not be very different between the three models. But I do think best batterylife will likely be M3-i5-i7 in terms of best battery life in one form or another.
From one or two early reviews I read that the i7 was getting a realistic noraml use all day batterylife 11-12 hours. So it's likely the i5 and M3 could potentially hit that 13,5 hour mark. Possibly more with Linus' tips.
johnwilliam9750
