SP2017 Build Quality Issue - oleophobic not consistently applied along edges
BatterseaDog
6
BatterseaDog
6
RESOLVED:* I received yet another i7 8GB unit today, and it could easily be used as a demo unit for the press.* It's beautiful.*
The bezel is securely attached to the screen above the camera and so there is zero light escaping from between the bezel and the screen even in a pitch black room (or closet, as it is now day here).* In addition, the oleophobic coating has been applied to the entire screen, unlike my i5 unit which had a 3mm gap in the coating along the left-hand side.
I was prepared to live with the oleophobic issue of the i5 unit should this i7 unit had arrived today faulty as well.* I was also would have been happy if the light leak between bezel and screen was only noticeable in a darkened room (with the camera light on).* Happily this unit doesn't suffer from any of the issues of my previous two units. So, both the oleophobic coating and bezel light leakage are both manufacturing build issues.
BevitalGluco2
