1. BajanSaint69's Avatar
    I've been having issues with my SP and the charger. It doesn't seem to be recognizing that the charger is connected.
    I had this happen once before, I swapped chargers with a friend who also has a SP and my SP recognised his charger, strangely his SP recognised MY charger. Given that we are outside of the US and a trip down to the Microsoft store isn't an option, we swapped chargers and he has reported no problems.
    Today I started to have the same issue again. Both times seem to have happened after the battery was run down to zero so I'm not sure if that's a factor. I've left it to charge to see if it does actually charge the battery despite it not seeing the charger.
    Like I said, I'm outside of the US or Europe and a quick trip down to the MS store for a warranty return isn't easily available. Has any one else had this problem?
    05-21-2018 07:09 PM
  2. excalibur1814's Avatar
    If you plug in the charger with the cable facing down try it facing up. Worth a shot.
    05-24-2018 03:32 AM
  3. BajanSaint69's Avatar
    tried that, clearly it's charging very slowly (about 3 days to reach full charge) looking for ideas...
    05-25-2018 04:42 PM
  4. BajanSaint69's Avatar
    Changed the charger back to my original charger and it's charging happily again!
    I'm stumped.
    My original charger has now come back home...….
    05-27-2018 01:05 PM
  1. Replies: 2
    Last Post: 06-04-2018, 04:29 PM
  2. Surface Book 2 Charger keeps disconnecting every 2 seconds
    By Manoj Daran in forum Microsoft Surface Book 2
    Last Post: 06-03-2018, 04:44 AM
  3. Why Microsoft might go with an Intel chip in a new budget 10-inch Surface
    Last Post: 05-21-2018, 08:10 AM
  4. Replies: 2
    Last Post: 05-20-2018, 11:18 AM
  5. Charge your phone wirelessly for only $10 with RAVPower's Fast Charging Pad
    Last Post: 05-19-2018, 03:40 PM
