Upgrading to a Surface pro 3 from Original Surface RT
CoatsyJnr
17
I have always been eyeing the pros. I had preordered my surface RT, so I've had it since day one. I use it often, but not everyday, being able to do what I need. Is it worth making the Pro 3 a reason to get a new device?
Nimdock
687
That is really a tough question for everyone but you to answer.
If you feel that you are lacking a bigger screen plus win32 applications then the answer would be go for it!! :)
WillysJeepMan
Aug 7, 2008
1,066
Only if it can replace your notebook (if you have one). As a direct replacement for the RT, it isn't worth it, but if it can replace a tablet and notebook, then it could be worth it.
kuyhaa
