1. Zumomaki's Avatar
    If you could get any of these at the same price wich one would you take?
    I would mainly use it for school, some media, and maybe some basic gaming, but not sure if the pros of the surface pro 3 are worth 64GB of storage and the i5
    05-31-2014 06:39 PM
  2. Qtweeder's Avatar
    just so you are aware, incase it was of any importance to you....the sp3 does "connected standby" which means it can 'wake' and display notifications / toasts while in low power mode, like our smartphones, the sp2 cannot.
    which is handy if you like to see everything as it comes through, rather than having to wake it up and check manually
    05-31-2014 06:50 PM
  3. onlysublime's Avatar
    there's no way you should get an i3 64GB over the i5 128 GB. if you plan on doing a lot with a computer, you can't go with only 64GB and with a far inferior CPU.
    Plus, the SP3 has more pixels to drive which means with the same CPU, it's slower. So an SP2 with i5 is faster than an SP3 with i5. So now if you're giving the SP3 the i3, that just makes it worse.
    the only reason to go with the SP3 in this case is if you really want the larger screen. but if you can handle the SP2 screen size, it's would be much more beneficial to go with that. You want room to grow with a machine. I already think 128 GB is barely doable because remember Windows apps only install on drive C:. And even if you install something like Adobe Creative Suite on your memory card on drive D:, some parts of the program still gets installed in various places on drive C:.
    As for connected standby, I wish the SP2 had it. It's wonderful on my Surface RT. I just plop down the keyboard and it wakes up instantly.
    rdubmu and WillysJeepMan like this.
    05-31-2014 10:46 PM
  4. carlos12001's Avatar
    I3 inferior?
    05-31-2014 10:55 PM
  5. onlysublime's Avatar
    yes, i3 is inferior. benchmarks will tell the story. also, we have quite a few i3 machines at work and they're all pretty horrible. maybe if you're used to an Atom, the i3 will feel okay. Or maybe if you're accustomed to Celeron machines which are terrible as well.
    05-31-2014 11:02 PM
  6. carlos12001's Avatar
    Nope, sp2 here, i5 64gb. Not my storage choice, got it on a trade.
    05-31-2014 11:12 PM
  7. SwimSwim's Avatar
    Benchmarks aren't everything, and my school has machines with i5 that still manage to be slow as ****.
    My friend, you must remember that while specs help: They aren't everything. Android vs. iOS/Windows Phone is proof enough of that.
    05-31-2014 11:23 PM
  8. carlos12001's Avatar
    An i5 machine that slow has something wrong with it, my sp2 flies....
    05-31-2014 11:46 PM
  9. fc000's Avatar
    The SP3 with i3 doesn't have Turbo, so your clock speed is stuck at 1.5GHz, whereas the i5 is clocked at 1.9 GHz, and Turbos to 2.9 GHz. That alone will make a difference in any intensive tasks.
    If you're just browsing the web, taking notes, and making use of light apps, an i3 will do... but a tablet at $849 (Canadian), you may as well splurge a little bit more, and get a much more capable processor with a big increase in storage space on a tablet that you'd like to think would last a few years.
    06-01-2014 12:00 AM
  10. onlysublime's Avatar
    Android/Windows Phone is a terrible analogy. They are different operating systems.
    You will not find a situation where i3 will run close to an i5 (ON THE SAME OPERATING SYSTEM) unless you only have 2 GB of RAM and you give the i3 an SSD and the i5 a HDD or you're doing really lightweight work like notepad, web browsing, playing music, etc. We reserve the i3 machines for the secretaries who do the word processing and calendar scheduling. Anyone higher get at least i5 machines (the bosses and upper management get the i7).
    06-01-2014 12:40 AM
  11. SwimSwim's Avatar
    Mine does too. I'm just making the point that specs, while very helpful, aren't everything.
    06-02-2014 07:16 PM
  1. Heart rate device compatible w/WP 8 or 8.1?
    By Ken Kilty in forum Cases & Accessories
    Last Post: 01-19-2015, 10:54 AM
  2. Dell Venue 8 Pro vs Google Nexus 7 2014
    By undulose in forum Dell Venue 8 Pro
    Last Post: 06-08-2014, 04:18 PM
  3. Clear influence of Surface design on Lumia 630
    By ininjam in forum Nokia Lumia 630
    Last Post: 06-04-2014, 04:55 AM
  4. Surface pro 3 price fix
    By Christopher Lindsay in forum Microsoft Surface Pro 3
    Last Post: 05-31-2014, 02:08 PM
