1. SPS828's Avatar
    I just got the SP3 (Intel i5 128GB 4GB RAM) yesterday and installed Sony Vegas Pro 12.0 and was wondering if the SP3 can handle rendering in 720p or is there too little RAM in it.
    Sent from my Surface Pro 3 using Tapatalk
    06-23-2014 11:16 PM
  2. jaimeastin's Avatar
    You try it and tell us, lol.;)
    Wyn6 and mrZoSo like this.
    06-23-2014 11:27 PM
  3. LuvMeSomeWP's Avatar
    You should've fired up Bing on your shiny new SP3 and searched something like, oh I don't know, "Sony Vegas 12 requirements"?
    http://www.sony.co.uk/pro/product/br...pecifications/
    Minimum requirements
    • Microsoft Windows Vista 64-bit SP2, or Windows 7 64-bit
    • 2 GHz processor (multicore or multiprocessor CPU recommended for HD or stereoscopic 3D)
    • 500 MB hard-disk space for program installation
    • 4 GB RAM (8 GB recommended)
    • OpenCL™-supported NVIDIA, AMD/ATI™, or Intel GPU with 512MB memory or more, for GPU-accelerated video processing and rendering
    • IEEE-1394DV card (for DV and HDV capture and print-to-tape)
    • USB 2.0 connection (for importing from AVCHD, XDCAM EX, NXCAM, or DVD camcorders)
    • Windows-compatible sound card
    • DVD-ROM drive (for installation from a DVD only)
    • Supported CD-recordable drive(for CD burning only)
    • Supported DVD-recordable drive (for DVD burning only)
    • Supported BD-R/-RE drive (for Blu-ray Disc™ burning only)
    • Microsoft .NET Framework 3.51 (included on application disc)
    • Apple QuickTime 7.1.6 or later for reading and writing QuickTime files
    • Internet connection (for GracenoteMusicID Service)
    So yes it will run, but it may take longer to render.
    06-24-2014 03:08 PM
  4. SPS828's Avatar
    • OpenCL-supported NVIDIA, AMD/ATI, or Intel GPU with 512MB memory or more, for GPU-accelerated video processing and rendering
    • Supported BD-R/-RE drive (for Blu-ray Disc burning only)
    Thanks!
    Sent from my iPad using Tapatalk
    06-24-2014 03:38 PM
  5. bkydcmpr's Avatar
    Thanks!
    you have the sp3, and you have sony vegas installed, and your result is?
    06-25-2014 05:02 AM
  1. Will Nokia icon work in Canada?
    By levi96 in forum Nokia Lumia Icon
    Last Post: 10-09-2014, 04:47 PM
  2. Is it too late to buy a Surface RT?
    By nelsonecm in forum Microsoft Surface for Windows RT
    Last Post: 08-24-2014, 10:51 AM
  3. Doubling songs in playlist
    By dkp23 in forum Groove Music
    Last Post: 07-14-2014, 05:07 AM
  4. Microsoft gives a behind the scenes tour of Surface Pro 3 commercial
    Last Post: 06-23-2014, 06:30 PM
  5. One week to go, get your #MobileFit steps in!
    Last Post: 06-23-2014, 05:42 PM
