1. jordanzhninja's Avatar
    So today I was doing a battery drain test, I switched to firefox instead of chrome for it. In two hours (19:45 - 21:45) whilst using 15 firefox tabs, onenote, about 30 minutes worth of debugging in VS professional, skype, hexchat, outlook 2013 and some metro apps in the background, I'm down to 58%.
    That means that continuing with my current usage I would get 4 hours in total, which is 5 less than microsoft claims.
    2. The kickstand works fine, but I find it a bit stiffer to get to 22 degrees than the Surface RT, also when it is between 22 degrees and 150 degrees, I can shake the kickstand and it wobbles a lot but doesnt move because of the friction hinge. Also at some angles when I put it down on a surface like my bed or lap the kickstand moves slightly
    09-10-2014 03:48 PM
  2. RajeevT's Avatar
    Might be because between the left and right sides there is some give so they may be slightly misaligned.
    Adam_ation likes this.
    09-10-2014 04:54 PM
  3. Adam_ation's Avatar
    I noticed this yesterday, i thought my replacement sp3 had a wonky kickstand. It helps if you pull out the kickstand with a hand on each side as opposed to just pulling it out from one side - Adam
    RajeevT likes this.
    09-12-2014 06:18 AM
  4. xboxonthego3's Avatar
    Microsoft never said 9 hours of battery life for everything. If you go to the Microsoft store webpage and look at tech specs. It states "Up to 9 hours of battery life for web browsing. Battery life for other uses will vary." Visual studios can be demanding. And I from what I have heard firefox can be somewhat demanding with many tabs open. But if you are doing what you said all at the same time of course you can expect your battery life to be lower than 9. Something to keep in mind in the future don't expect any machine to get what the manufacturer says is the battery life because there is usually a catch and everyone uses a PC differently.
    Also on the kickstand what everyone else said is true. There is another thread about it as well. There is also a thread for a loose kickstand or a kickstand that gives way if you search as well.
    Hope this is helpful!
    09-12-2014 01:33 PM
  5. jordanzhninja's Avatar
    This is the issue: https://vine.co/v/MEqH39Xh66X
    I cant return it for a new one because that voids my cashback :(
    Although I did pay for Knowhow Currys PC world support, do you think that will cover it
    I really dont know what to do :(
    09-12-2014 04:26 PM
  6. astell's Avatar
    That is normal. Mine does it and I've never had a problem with the kickstand. It isn't going to be as stiff as previous models because it isn't a fixed kickstand it is fully adjustable. As for the battery life? Microsoft never said 9 hours under heavy multi tasking. They said 9 hours web browsing. Vast difference.
    09-12-2014 04:40 PM
  7. jordanzhninja's Avatar
    It is normal? Thanks, thats a relief. And ok about the battery
    09-12-2014 04:42 PM
  1. Replies: 6
    Last Post: 02-16-2015, 04:01 AM
  2. What do you think of Microsoft buying Mojang?
    By Jas00555 in forum Microsoft News & Rumors
    Last Post: 10-01-2014, 07:21 AM
  3. Replies: 1
    Last Post: 09-14-2014, 02:55 PM
  4. Replies: 1
    Last Post: 09-10-2014, 06:37 PM
  5. Nokia features gone after a factory reset.on 8.1.
    By NightOrchid in forum Nokia Lumia 1520
    Last Post: 09-10-2014, 04:48 PM
