I have a very strange problem with my new Surface:
Whatever I have in my Onedrive doesn't appear on my new surface (App or File Explorer).
In the first set up started to sync for some hours, then finished and from that time insists that everything is synced and updated, but I see nothing inside after 3 days...
Off course through Internet Explorer (Web) I can perfectly see everything.
From my other machines, my files are fully accessible and have the indication ''available offline'' as they should.
All the options on my surface permit to sync and have everything available offline.
Any ideas are more than welcomed
(Update: I tried also to uninstall and reinstall Onedrive to no avail...)
(Update No2: Fixed,after a complete refresh, everything is working now as it should be)
