Anyone lose the ability to swipe down from top edge?!?
spinedoc
21
This is a weird issue, I can only seem to swipe down from the top edge in about an inch wide area towards the left side of my top edge, everywhere else I cannot swipe, it won't register.
I fear the digitizer is failing, this is the same area where sometimes it won't detect my finger presses. Although in this case it does detect my finger properly, it just doesn't recognize I'm swiping in from the edge. Really weird. This is my 3rd replacement and going on the 4th one I suppose, I'm really losing faith in this hardware.
Pete The Penguin
1,039
Sounds like a bad batch.
I'd get your money back and wait aabout 8 weeks for new stock to filter through.
stephen_az
Banned
Aug 2, 2012
1,267
Try calibrating the screen through the control panel before going the return route. If calibrating does not work, which I have generally found to be the case, go back to the utility and choose reset. I have actually fixed a few quirks with SP through SP3 by resetting.
jacobss
