1. Sin Ogaris's Avatar
    Just picked myself up the i7/256GB SP3. So yeah, I'm going to get crazy with the Windows 8-ness.
    As an aside, can the sp3 be set up as a dual boot for Windows 10 preview?
    10-24-2014 09:29 AM
  2. Pete's Avatar
    Yay for another Surface Pro 3 user!
    You might want to look at using Hyper-V to install Windows 10. If things go pear shaped, you can just delete the virtual machine.
    Running virtual machines on Windows 8 with Client Hyper-V - Windows Help
    Check out this link as a starting point.
    Run Windows 10 in Hyper-V | Skrakes.com
    Then Bing your way to other advice as you see fit.
    Nakia Johnson1 likes this.
    10-24-2014 09:34 AM
  3. Sin Ogaris's Avatar
    Trying to set it up now, I'm following the word doc from Microsoft's site but it keeps coming up with an error when I input the command line into Powershell, I'll play around with it tomorrow.
    10-24-2014 10:53 AM
  1. Why wont my mkv's play thought the media player
    By marboba in forum The Xbox Lounge
    Last Post: 11-02-2015, 01:14 PM
  2. Tired of waiting... going to 8.1DP...
    By dki378 in forum Nokia Lumia Icon
    Last Post: 10-31-2014, 10:49 PM
  3. Where have the music players gone?
    By martin joseph in forum Microsoft News & Rumors
    Last Post: 10-26-2014, 01:14 PM
  4. The Video App - What is Microsoft doing?
    By Mohammed Bugedwala in forum Applications
    Last Post: 10-25-2014, 03:20 AM
  5. Costemtic Bug : WPCentral in the main site footer
    By Lance_WPCentral in forum Site Feedback & Help
    Last Post: 10-24-2014, 09:06 AM
