1. gbafam's Avatar
    I'm very pleased with my surface pro 3. That said, I've had trouble with the stylus, on an irregular basis, failing to write. When you push the top of the stylus, it connects fine with one note, so it doesn't seem to be a pairing issue. Nor am I not able to figure out why it quits working (and when it quits working, you not only can't write with it (a function I'm a heavy user of), you can't use the stylus to access menus or other functions, either. When it quits working, it sometimes starts up again a little while later, but nothing in particular seems to trigger pen performance or failure to perform.
    ​I've only had the surface pro a few months so I'd assume batteries can't be the issue. any suggestions?
    12-09-2014 04:53 PM
  2. Dr Dan's Avatar
    I have the same problems. Recently, I took my Surface Pro 3 and Stylus to the Microsoft Store. The sales associate saw the problem and replaced the Stylus on the spot, but the problem has reoccurred. I am currently running the Technical Preview and now the store blames the Technical Preview.
    12-09-2014 07:29 PM
  3. Mr_Kirill's Avatar
    It's probably loosing bluetooth connectivity - next time it happends see it still connected under bluetooth devices.
    There is some setting "allow power management for bluetooth devices" - try disabling it
    12-11-2014 04:00 PM
  1. Replies: 6
    Last Post: 01-15-2016, 10:33 AM
  2. Outlook 2013 on 9879 issue using OneDrive
    By Realanswerman in forum Windows 10 Insider Preview
    Last Post: 12-11-2014, 04:04 PM
  3. Does Microsoft provide a payment plan for purchasing the Surface Pro 3?
    Last Post: 12-09-2014, 02:18 PM
  4. Review - Inateck Felt Surface Sleeve for Surface Pro 3
    Last Post: 12-09-2014, 02:11 PM
  5. Juiced 5-in-1 Connector Kit for Surface
    By Philip Hamm in forum Microsoft Surface for Windows RT
    Last Post: 12-09-2014, 10:43 AM
