1. Aman1007's Avatar
    Hi...
    Going to a Law School This Year..
    Planning to Buy a Laptop and a Mobile...
    For Laptop I will be going with SP3...
    I am confused with buying Lumia 650 or BlackBerry Q10..
    I want to know that which combination is best for overall productivity...Lumia 650 will not have continuum and so will it be huge different choosing Lumia over BB Q10 to have a complete ecosystem....
    04-03-2016 10:47 PM
  2. Chintan Gohel's Avatar
    Hi...
    I think it would be better to quantify your needs from a phone and then check which of the two phones can satisfy the most needs. Certainly using the 650 will be very familiar for you since the layout and apps generally look the same in the surface. There are chances of finding apps with the lumia but not on the BB
    04-04-2016 05:37 AM
  3. fgol's Avatar
    There's nice integration between a Windows 10 mobile device and a Surface Pro (or any laptop) that's also running Windows 10. When they're connected via Bluetooth you will be able to send texts through the phone from the SP3, and also see phone notifications and texts on the SP3.
    04-04-2016 05:47 PM
  4. Laura Knotek's Avatar
    Hi...
    How about the BlackBerry Priv?
    xandros9 likes this.
    04-04-2016 06:03 PM
  5. snowboarders's Avatar
    I would get the Lumia 950 with more power full space the 650 has vary low end space I don't think you be happy with it
    04-28-2016 03:25 PM
  6. xandros9's Avatar
    But its twice as expensive. As long as OP tosses in a microSD card, he'll be fine.
    04-28-2016 07:17 PM
  1. Bricked Lumia 930 - help!
    By hasasimo in forum Nokia Lumia 930
    Last Post: 01-26-2019, 02:14 AM
  2. Lumia 1520.3 and two cases for $250 OBO
    By suburbanl3g3nd in forum Marketplace Archive
    Last Post: 04-13-2016, 06:38 PM
  3. Which Model Should I Get?
    By Fred Tam in forum Microsoft Surface Pro 4
    Last Post: 04-10-2016, 09:43 PM
  4. Replies: 2
    Last Post: 04-06-2016, 02:16 PM
  5. Batman vs Superman vs the Lumia 950XL
    By Rican914 in forum Microsoft Lumia 950 XL
    Last Post: 04-03-2016, 07:05 PM
