1. markreed's Avatar
    Hey guys, how can you tell if you have a new charger since the recall or the original one? I'm asking because I got my surface used and the charger just caught fire, i'm assuming that means it's likely an old one but would like to be sure
    thanks
    04-23-2016 08:35 PM
  2. markreed's Avatar
    just checked the recall webpage, seems I have the new one. think I should complain to Microsoft?
    04-23-2016 08:37 PM
  3. markreed's Avatar
    p.s. it's not the cable that caught fire but the actual power block, it's bloody stinks
    04-23-2016 08:45 PM
  4. Guzzler3's Avatar
    Always contact the manufacturer when ever some thing catches on fire.
    EMitchell likes this.
    04-24-2016 11:57 PM
  5. Racing Snake's Avatar
    The recall was for the plug-cable only, the charger itself was not recalled.
    But as per above, go back to the manufacturer.
    05-03-2016 08:18 AM
  6. Grodelj's Avatar
    Did you contact MS?
    05-23-2016 12:48 PM
  1. idk what to do with this surface pro 2
    Last Post: 04-23-2016, 03:19 PM
  2. Thoughts on surface 3
    By Chintan Gohel in forum Microsoft Surface 3
    Last Post: 04-23-2016, 01:14 PM
  3. Surface 3 Dock Sale for 129,99$ at BestBuy Canada
    By Francis_Beland in forum Microsoft Surface 3
    Last Post: 04-22-2016, 06:17 PM
  4. Why doesn't my Surface dock updater update?
    Last Post: 04-22-2016, 04:17 PM
  5. 10 tips and tricks to make you a Cortana pro on Windows 10
    Last Post: 04-22-2016, 03:42 PM
