1. davo_svk's Avatar
    Hello!
    Today I did Factory reset, on my Surface Pro 3 with WIndows 10.
    But factory reset did cleaninstall of Windows 8.1.
    Now I'm not able to go back to Windows 10. What I have to do ??
    Thank you for any help!
    07-31-2016 12:41 PM
  2. Chintan Gohel's Avatar
    Hello!
    how did you do the reset? Did you use an ISO file or something similar
    Check this thread for a method: http://forums.windowscentral.com/win...ml#post3529058
    davo_svk likes this.
    08-01-2016 12:07 AM
  3. davo_svk's Avatar
    I did factory reset through settings..
    But its now solved, I just downloaded mediacreationtool and upgraded it there
    Chintan Gohel likes this.
    08-01-2016 01:47 PM
  1. Bluetooth problem
    By maplebank in forum Samsung Galaxy TabPro S
    Last Post: 08-14-2016, 09:11 AM
  2. Microsoft Edge Problems
    By BonsaiGuy in forum Ask a Question
    Last Post: 08-02-2016, 12:29 AM
  3. Replies: 2
    Last Post: 08-01-2016, 01:01 PM
  4. Windows 10 Mobile MicrosoftMDG Update- Problem.. Help Asap
    By Hamras Hamza in forum Ask a Question
    Last Post: 08-01-2016, 06:48 AM
  5. If I reset win 10 (1st option under recovery) can I still roll back to win 7?
    Last Post: 08-01-2016, 12:02 AM
