What is the expected battery life of the Surface Pro 4?
onysi
902
i thought skylake would increase battery life or something. This is annoying. I want a tablet that can at least reach 12 hrs.
BGrewer
276
Well I'm currently getting an average of ~8hrs (Pro 3, i5) of battery life, but this is a collective mix of Office, Apps, internet (YouTube, Google scholar, etc.) But I feel your pain, its annoying that you can't get at least get a days worth of battery, it would have also been nice if they'd released a power cover with the Pro 4.
Christopher Senn1
43
the new skylakes definitely use less power. Plus no fan. Plus no overheating, thus slowing down the processor.
Maybe 10-12?
Wonder what the differences will be between the i3 and i7 battery life
bo_woods
1,449
Maybe 10-12?
There is no i3 Surface Pro 4...
There is the Core M3, Core i5 and Core i7...
The Core M is without a fan, while I'm not sure whether or not the i5 and i7 models have a fan ( I'm more so leaning towards them having a fan)
Rooks308
86
Also, here is the battery life info.
https://forums.windowscentral.com/e...surface-pro-4%23techspec-block&token=n1GWJ4wY
If you read the fine print it says this about which CPU they get the 9 hours battery life rating from and how they got it.
"2 Testing conducted by Microsoft in September 2015 using preproduction Intel? Core? i5, 256GB, 8 GB RAM device. Testing consisted of full battery discharge during video playback. All settings were default except: Wi-Fi was associated with a network. Battery life varies significantly with settings, usage, and other factors."
This leads me to believe that realistically if you are using it beyond light duty you'll probably get in the 6-7 hours range. Maybe 8 if you dim the screen.
I am sure it can probably pull a full 9 hours in light duty usage though.
DrPendragon
