boltman2013
Banned
Try using just 2.4GHz (not 5GHz) switch on wireless setting. Perhaps switch channel on router to 1, 6 or 11.
Also double check Windows Firewall and allow adapter through.
I know its Miracast but it still uses your wifi card
Also try shortening the distance and resetting (button 10 seconds) or unplugging the dongle.
Sounds to me its likely either to far away or interference. or just needs reset.
