W Windows Central Question Dec 14, 2015 #1 what does the small antenna on the case for the microsoft surface pro 4 mean case for MS surface pro 4
B boltman2013 Banned May 12, 2014 787 0 0 Visit site Dec 16, 2015 #2 Re: what does the small antenna on the case for the microsoft surface pro 4 mean Windows Central Question said: case for MS surface pro 4 Click to expand... I don't think anyone understands what you are asking. By case do you mean the Magnesium shell? What antenna ? Where is it? a Is it literally an antenna or a symbol? Upvote 0 Downvote
wpjuanra New member Oct 24, 2013 9 0 1 Visit site Dec 18, 2015 #3 Re: what does the small antenna on the case for the microsoft surface pro 4 mean Do you mean the tab at the top corner of Urban Armor Gear case? It can be used to prevent the type cover from opening accidentally. Last edited: Dec 19, 2015 Upvote 0 Downvote
