Just to let people know in case it helps someone. I was having loads of problems with my Pro 4 - mainly the usual reported ones. Was waiting for the sleep fix before worrying but that didn't fix everything for me. In fact after that, I started getting the odd random freeze. So I phoned MS and they recommended a reinstall on W10 (creating a usb boot disk). That was only last Wed, but since doing that I have had no issues at all.
Not saying it'll work for everyone and it may not even have worked for me (was only a few days ago), but possibly worth trying if you've been plagued. Means reinstalling apps and you have to remove bitlocker first, but no huge drama.
Cheers
Ross
Cheers
Ross
