    At first the fan was on non-stop but after restarting the surface a couple of times there was an update that was installed and the fan stopped. I thought the issue was fixed but now when my surface heats up the fan never worked and sometimes I get a black screen that shows a thermostat which I am assuming means that the surface overheated. Usually when I am playing Hearthstone the fan starts up 5 minutes into the game but now I spend hours and nothing, it just heats up a lot and fan never turns on.
    Anyone else with this problem?
    04-27-2016 07:56 PM
  2. Chintan Gohel's Avatar
    it could be a hardware problem - is there a service centre nearby that you can go to? I'm assuming your sp4 is still under warranty
    05-06-2016 06:04 AM
  3. a_bain_uk's Avatar
    Same things happening to me, I'm currently sat resetting the surface to factory settings to see if it fixes the problem.
    05-12-2016 01:41 PM
  1. Can I make OneDrive work like this?
    By Windows Central Question in forum OneDrive
    Last Post: 05-06-2016, 06:10 AM
  2. Replies: 1
    Last Post: 04-28-2016, 03:53 AM
  3. Why can't I get my recovery DVD working?
    By Windows Central Question in forum Acer
    Last Post: 04-27-2016, 06:31 PM
  4. Free up photos space on Windows 10 Mobile?
    Last Post: 04-27-2016, 06:29 PM
  5. Travelling with Continuum: When the stars (and ports) don't align
    Last Post: 04-27-2016, 02:30 PM
