1. Lone Swordsman's Avatar
    Here's the deal: I currently have a six-year-old Sony VAIO laptop that serves as backup for my desktop, in case I need to get work done just that badly. A Surface would potentially be a wonderful upgrade, but money is tight and frankly, I don't need something with desktop-level specs.
    So then - how well does the base-level (Core M3, 4GB RAM, 128GB SSD) Pro 4 handle apps like Photoshop CC and Office? Just about anything would be better than my old laptop, but of course, I want to go in the right direction.
    08-18-2016 11:58 AM
  2. jo-pa's Avatar
    Check out my post above, about which SP config would be the best, some users posted some great responses. I am looking to do much of the same thing you are as well. I have a base level SP3 which does many of the things you mentioned above with no problem. It is a very practical device, I really enjoy using it.
    08-18-2016 12:38 PM
  3. Lone Swordsman's Avatar
    Thanks for feedback on that one, I'll check the other thread too. You should see the old VAIO in action - it keeps popping in and out of Aero graphics in Windows 7, even though it has a dedicated graphics card.
    08-18-2016 01:40 PM
  4. demon09's Avatar
    To be honest, I've been seeing the core i5 model for less than the core M one in some places. I'm using the i5 with 4gb of ram and it works very, very well. I don't run too many intensive programs on it, but I'm using an almost identical SP3 at work and it does photoshop and some other more intensive programs just fine for quick edits and things.
    overboard08 likes this.
    08-18-2016 10:35 PM
  5. Lone Swordsman's Avatar
    I'd certainly prefer to get an i5 model if I can. Of course the ideal would be to get a configuration that's a little more future-proof (8GB of RAM, etc.), but Surfaces can get very pricey very quickly.
    08-19-2016 07:10 AM
  1. How to turn off automatic syncing in OneDrive?
    Last Post: 08-19-2016, 06:44 PM
  2. how do i fix KMODE_EXCEPTION_NOT_HANDLED?
    Last Post: 08-19-2016, 01:57 AM
  3. Question: Wall Paper for the 950XL
    By kristalsoldier in forum Microsoft Lumia 950 XL
    Last Post: 08-18-2016, 10:22 PM
  4. Microsoft's PowerShell is now open sourced; available for Linux and OS X
    Last Post: 08-18-2016, 01:18 PM
  5. Here are the near-final designs for Eve's 'Pyramid Flipper' Windows 10 2-in-1
    Last Post: 08-18-2016, 11:30 AM
