1. Kojidog's Avatar
    Hi everyone and thank you for reading.
    This happened a couple weeks ago. It happens with all drawing apps, Paint, note, ect...
    There is a column in the middle where I'm unable to draw correctly. I had calibrated the pen once before but it didn't work. I updated again but now I can't get to the pen calibration.
    I saw a friend's link, that I cant find anymore, that said that if you find this problem your surface is broken and has to be returned.
    Any thoughts or help people?[IMG][/IMG]
    08-21-2016 08:51 PM
  2. Chintan Gohel's Avatar
    this does look like a hardware issue. Does touch work in that centre column?
    08-21-2016 11:56 PM
  3. Stephen Lau's Avatar
    Thanks for pointing out.
    08-22-2016 03:00 AM
  4. lampuiho's Avatar
    Any update? My Hp elite x2 is getting the same problem.
    05-21-2018 12:29 AM
  5. Zecajacintho's Avatar
    Hi! My Surface Pro4 is having a similar problem - there is a horizontal line where the pen loses its accuracy. The problematic line is at the time of USB input. I was able to delimit her in the drawing below.
    I use OneNote and DrawBoardPDF, and both are giving the same problem in the same place.
    05-28-2018 04:33 PM
  6. hamidparham's Avatar
    I'm having this same problem at the bottom of my sp4 screen. Does anyone have any update on this?
    08-12-2018 06:38 AM
  1. Problem in Anniversary update 😭
    By DavidTheGiant in forum Windows 10 Mobile
    Last Post: 08-24-2016, 03:22 AM
  2. 930 screen flickering
    By BataBole in forum Nokia Lumia 930
    Last Post: 08-23-2016, 04:01 AM
  3. where is windows media player in windows10
    Last Post: 08-22-2016, 12:18 AM
  4. How can i turn off touch screen on Windows 10 V 1607 for Surface Pro 3
    Last Post: 08-22-2016, 12:16 AM
  5. Why the sounds of system in the anniversary update is very low and muffled?
    Last Post: 08-21-2016, 11:51 PM
