1. ricardo_1960's Avatar
    About three weeks ago I allowed an automatic windows update to take place overnight. The next day when I turned on my tablet this sign came up:
    “ Your computer was not turned off properly, please press here to re-start.” Up until today it hasn’t re-started. I took it to the Microsoft store and they told me there was nothing they could do. It was totally useless. They suggested I buy a new one at a discount.
    Has any one ran into a similar situation? The tablet is almost new.
    Any advice anyone can give me will be greatly appreciated. If anyone has a number where I can call to get help, please share it with me. I honestly think Microsoft should be held liable.
    Kind regards,
    Ricardo
    04-05-2018 05:37 PM
  2. Adventurer64's Avatar
    Can you boot from a USB flash drive? I have an older 8" tablet that I thought was bricked after a failed insider build install and was able to recover by booting from a backup USB drive I created that contained original Windows version that came preinstalled on tablet. Sounds like the personal at your MS store aren't very helpful.
    El_Burro likes this.
    04-06-2018 08:04 AM
  3. ricardo_1960's Avatar
    Hey, thanks for your response. They tried the USB to boot it at the store, but didn’t work.
    04-06-2018 01:22 PM
  4. Adventurer64's Avatar
    That's not good. Sorry for your loss. Are you going to buy another Surface or move on to another brand?
    04-06-2018 08:40 PM
  5. meattray's Avatar
    you've held the power and volume up to reboot?
    04-06-2018 10:22 PM
  6. miodrage's Avatar
    Hold down power and volume up for about 30 secs, the device should boot up in a safety mode asking u what to do. Then select fresh install, and install from USB. If this fails, then it means u have a hardware fault. U say ur device is almost new, so u have to have a warranty. Return it, and demand either an express repairment, or a new device.
    04-07-2018 04:28 AM
  7. ricardo_1960's Avatar
    Thank you for your advise. Unfortunately that didn’t work either. It’s been about 15 months since I bought it, so there’s no warranty. At this point I’m trying to find a number where I can call and speak to some one high up with in the Microsoft company. I appreciate any help I can get.
    04-07-2018 01:52 PM
  8. miodrage's Avatar
    Is the device responding to charging?
    04-08-2018 03:32 PM
  9. Trakmeister's Avatar
    I have a similar problem. 15 month old Pro4. 3 days ago after auto update of system driver 2.0.2.0 it started crashing after 5-10min of operstion. Took me to UEFI screen then rebooted and kept cycling through. Similar to a fault I read with a recent Windows 10 update for some SSD machines. When I first rang Microsoft I couldn’t get the Surface Diagnostic tool to run long enough so they said it was a hardware fault and I should pay for a changeover. But it seemed to be driver related so I persevered and eventually Diagnostic ran long enough to complete and say there was nothing wrong. But it kept crashing. Then it stopped booting into windows and it was running check disk at start up. But always stopped and crashed. I’ve created a boot USB to reinstall Windows and it can see the partitions but won’t install. I run diskpart and similarly it can identify the partitions but not see the disk drive. So sounds like the SSD driver is defective.
    When I get on a computer tomorrow I will download the MS driver from the website. Does anyone know which actual driver file contains the SSD driver? I’ve read that the drives are Samsung NVMe and you can use Samsung drivers but I’d prefer to try to use MS first.
    06-07-2018 11:51 PM
  1. Dropped my phone in water, seems fine if just for wifi
    By Erica Engelhard in forum Ask a Question
    Last Post: 04-06-2018, 09:31 AM
  2. Toast wood cover for Surface Laptop is the best way to cover any dings or scratches
    Last Post: 04-05-2018, 12:40 PM
  3. 50 influencers Windows users and Microsoft fans need to watch
    Last Post: 04-05-2018, 11:10 AM
  4. Learn everything you need to know about web development for only $35!
    Last Post: 04-05-2018, 10:40 AM
  5. Can I Import My Spotify Playlist To Groove Music?
    By ethelena in forum Ask a Question
    Last Post: 04-05-2018, 08:37 AM
