Battery Replacement. Is it an option
Jcmg62
Member
Oct 8, 2013
760
9
18
I've had my SP4 for about 3 years now and use it every day as my primary device for work and leisure.
The nett result of using it extensively (10-12 hours a day) is that the battery life has really started to shorten significantly.
Typically, a full charge will now run down in about 3-4 hours, maximum.
Is a battery replacement an option with the Surface Pro range?
libra89
Feb 6, 2015
11,076
6
38
Aside from the Microsoft store, I'm not sure. I remember hearing that the repair is challenging for Surface products.
Jcmg62
Member
Oct 8, 2013
760
9
18
Yup, you're right. I've just spoken with an MS support agent. They offer a refurb programme, but it's still quite expensive.
There's no straight battery replacement solution.
Apparently, the batteries are glued in, and also somehow connected directly to the motherboard, so getting to them is super tricky.
Oh well, take care of your surface, folks. If it needs any internal repairs done, it's going to cost big time
libra89
Feb 6, 2015
11,076
6
38
That's a bummer. Thank you for reporting back, as this would be useful for anyone who also wanted to know this.
xandros9
Nov 12, 2012
16,107
This is why I’m hesitant to recommend the Surface, current Mac portables and similar computers as the cost and complexity of repair is through the roof. They’re basically designed to be disposable computers.
But they sure are pretty though.
graceevans
