I've had my SP4 for about 3 years now and use it every day as my primary device for work and leisure.
The nett result of using it extensively (10-12 hours a day) is that the battery life has really started to shorten significantly.
Typically, a full charge will now run down in about 3-4 hours, maximum.
Is a battery replacement an option with the Surface Pro range?
