1. Jcmg62's Avatar
    I've had my SP4 for about 3 years now and use it every day as my primary device for work and leisure.
    The nett result of using it extensively (10-12 hours a day) is that the battery life has really started to shorten significantly.
    Typically, a full charge will now run down in about 3-4 hours, maximum.
    Is a battery replacement an option with the Surface Pro range?
    07-06-2018 07:38 AM
  2. libra89's Avatar
    Aside from the Microsoft store, I'm not sure. I remember hearing that the repair is challenging for Surface products.
    07-06-2018 09:47 AM
  3. Jcmg62's Avatar
    Yup, you're right. I've just spoken with an MS support agent. They offer a refurb programme, but it's still quite expensive.
    There's no straight battery replacement solution.
    Apparently, the batteries are glued in, and also somehow connected directly to the motherboard, so getting to them is super tricky.
    Oh well, take care of your surface, folks. If it needs any internal repairs done, it's going to cost big time
    libra89 likes this.
    07-06-2018 10:51 AM
  4. libra89's Avatar
    That's a bummer. Thank you for reporting back, as this would be useful for anyone who also wanted to know this.
    Jcmg62 likes this.
    07-06-2018 11:50 AM
  5. demusss's Avatar
    There's a guide on ifixit https://www.ifixit.com/Guide/Microso...lacement/60358
    It does look tricky to get the screen off.
    07-08-2018 05:16 AM
  6. xandros9's Avatar
    This is why I’m hesitant to recommend the Surface, current Mac portables and similar computers as the cost and complexity of repair is through the roof. They’re basically designed to be disposable computers.
    But they sure are pretty though.
    libra89 likes this.
    07-08-2018 08:11 AM
  1. Microsoft Account Payment options: "Redeem Bitcoin"
    By twotrident in forum Microsoft News & Rumors
    Last Post: 12-04-2018, 09:34 AM
  2. My microphone is always on
    By a4aa4a44 in forum Windows 10
    Last Post: 07-08-2018, 08:10 PM
  3. Microsoft is working on Movies & TV apps for Android and iOS
    Last Post: 07-05-2018, 12:40 PM
  4. Seagate's Firecuda SSHD is a great replacement for traditional hard drives in your PC
    Last Post: 07-05-2018, 08:10 AM
  5. Replies: 0
    Last Post: 07-05-2018, 06:05 AM
