1. rocky piccolo1's Avatar
    So I recently purcased a second hand surface pro 4. The previous owner had it for 1 year and I have had it for 5 months. Today I went to use t and it was working perfectly fine for 5 minutes and then all of a sudden the screen froze. So I held down the power button for 10 seconds and now it won’t turn on. I have tried all the reboot options and nothing worked. Microsoft said I have to get a replacement device but I don’t want to unless completely necessary
    08-09-2018 04:59 AM
  2. miodrage's Avatar
    Try to hold down power and vol down, or up, for 30 secs. Also, try that while attached to the charger.
    08-10-2018 04:05 PM
  3. HeyCori's Avatar
    Yes, if holding the power button for 30 seconds doesn't work, your next step is to take it to the extreme and disconnect/reconnect the battery. (which would involve taking the device apart). At 1.5 years old, it's unlikely it's still under warranty unless the original owner extended it.
    Laura Knotek likes this.
    08-10-2018 06:02 PM
  4. miodrage's Avatar
    Yes, and dismantling it means you have a good chance, 'bout 70% to break the screen. Sorry mate.
    08-12-2018 01:56 AM
  1. Replies: 2
    Last Post: 08-14-2018, 10:29 PM
  2. CrystalDiskMark: comparison of Surface Go to Surface 3
    By LibbyLA in forum Microsoft Surface Go
    Last Post: 08-11-2018, 11:14 AM
  3. Surface go and dragon dictate 15
    By NPMap in forum Microsoft Surface Go
    Last Post: 08-09-2018, 07:03 PM
  4. Here's how Monster Hunter: World runs on PC
    Last Post: 08-08-2018, 04:10 PM
  5. Ready your fists for Devil's Hunt on Xbox One
    Last Post: 08-08-2018, 03:50 PM
