1. garak0410's Avatar
    What causes the Surface Pro 2 to sometimes not go to sleep and then just run hot and have the fan kick on? Twice I've went back to my Surface Pro 2 and it was it and the fan was running. I had powered it off (set to sleep) and closed the cover before this happened. Runaway app?
    11-11-2013 02:22 PM
  2. bluetroll's Avatar
    open up task manager and take a look at what apps you have open.
    you can see which apps are using up cpu power.
    11-11-2013 08:24 PM
  3. garak0410's Avatar
    11-12-2013 09:51 AM
  4. garak0410's Avatar
    Yeah, I tried that...nothing was taking up CPU yet it was hot and fan was running. My original Pro did this from time to time. :(
    11-12-2013 09:53 AM
  5. superlawyer15's Avatar
    something doesn't sound right
    the fans on my SP2 are yet to kick in
    ..and I've been stressing it a bit, running games and such
    11-12-2013 10:43 AM
  6. MBytes's Avatar
    Sounds like putting the system to sleep, fails, and a bug makes the SP2 CPU loose all power management system.
    (I don't have any Surface product yet, so I can't test anything)
    You can diagnose the sleep system of Windows by simply:
    -> Open the command prompt as Administrator (Win+X > select: Command prompt (Admin)).
    Then type: cd c:\, hit ENTER
    Then type: powercfg -energy, hit ENTER
    Am HTML report will be generated in C:\
    Have a look.
    11-12-2013 10:01 PM
  1. Bluestacks On Surface Pro 2
    By garak0410 in forum Microsoft Surface Pro
    Last Post: 01-09-2014, 12:52 PM
  2. Reset phone and lost stereo audio
    By eagle628 in forum Windows Phones
    Last Post: 11-11-2013, 11:43 AM
  3. Windows Media Center and XBOX Music
    By garak0410 in forum Windows Apps
    Last Post: 11-11-2013, 10:40 AM
