Totally worth it! My Surface Pro 2 /is/ my laptop and tablet, it does a great job at both! I LOVE this thing, it's so worth it!
It's incredibly fast, fluid, and powerful. It's definitely heavy for a tablet, and while the battery isn't terrible, do be warned that it's still short compared to most tablets. I typically get through the day on a single charge, but I am sometimes desperate for power, so do keep that in mind.
Anyways, it's a fantastic device, Microsoft really did a great job. So long as you can put up with the following cons:
- Thick and bulky for a tablet. Not too horrible, especially for how power it has, but this ain't no iPad Air, that's for damn sure.
- Battery is very decent by the standards of most other devices with the same hardware, but once more: it doesn't hold a candle to a typical tablet.
- One USB is kickass while on the go, but you do need a dock if using this as your main machine, or that one port just won't cover everything.
- *DO NOT GET A TOUCH COVER!!!* I'm sorry, but those just aren't there yet. Touch cover is a definite con, avoid at all costs!
- The track pad on both the Type and Touch Covers, gen 1 and 2, SUCK. Thankfully, you get an awesome stylus and have a wonderful touch screen mere inches away, but I'd highly recommend and extra mouse, as the track pad is terrible.
- Display Port is great, but we live in a VGA/HDMI world, so you're likely going to need a converter(s).
.... Then you get the full benefit of (pun definitely intended) Pros:
- This thing is POWERFUL. It's super fast and just awesome. It's not the most powerful thing ever, but it's still pretty badass. This thing just breezes through daily tasks, and it's powerful enough for casual-moderate gaming, and it's also good for Photoshop on the go. Don't expect this to hold a candle to $2000+ gaming laptops or other professional high-end hardware, but this thing is more than powerful enough for 90%+ of daily tasks and activities.
- The stylus is incredible! Going for Wacom was a great idea. While it struggles at the corners, it's overall a really great stylus an works wonderfully. Do take care not to loose it, however, because there's no dedicated slot other than the charge port, and even then: it can easily be knocked out.
- Full Windows 8.1! Run 95%+ of any Windows program out there that your heart desires. Program you like? This machine has more than likely got it covered.
- I don't care what Apple or Amazon say: this 1080p screen is great! I'm not saying it wouldn't benefit from more pixels, but it ain't no slouch either. The screen is great, both in terms of looks and feel. Just make sure to scrub fingerprints and smudges off frequently, which is really easy.
- The speakers are really great quality! Sadly, their sound output is easily drowned out, so noise quickly kills the experience. Still, the sound is really crisp in quiet environments, they're great!
- The Type Cover is a dream to type on. It's ever-so-slightly smaller than a regular keyboard, so you'll be off at first. But once you adjust, it's just like typing on any regular keyboard, with full speed and accuracy.
- That one USB port still has most other tablets beat, it's very convenient to be able to use USB devices anywhere.
- A bazillion more!
So would I recommend? HELL YES!
