1. Izzmox's Avatar
    Does anyone know if the stylus for the Surface Pro 3 will work on the Surface Pro 2?
    05-20-2014 12:24 PM
  2. conorn's Avatar
    Doubt it, 2 is Wacom (?) and 3 is Ntrig - according to Tom W.
    xandros9 likes this.
    05-20-2014 12:31 PM
  3. Izzmox's Avatar
    From what I read, it looks like a no. Since the WACOM pen does not need a battery, but instead of a hardware layer between the pen and digitizer (behind the LCD), and the NTrig does not, they probably won't be compatible.
    05-20-2014 12:34 PM
  4. sd173's Avatar
    They must've made that sacrifice to make the Awesome Tablet 3 as thin as it is.
    05-20-2014 05:28 PM
  1. First Impressions on Microsoft Surface Pro 3.
    By Ankit Nawlakha in forum Microsoft Surface Pro
    Last Post: 06-28-2014, 11:08 PM
  2. Latest Skype for Xbox One update adds Snap support for video calls
    Last Post: 05-20-2014, 12:11 PM
  3. Microsoft shows why you should leave your laptop for the Surface Pro 3
    Last Post: 05-20-2014, 12:00 PM
