hopmedic
It also looks as though it does not support the Touch Cover magnetic feature.
The case seems to keep the Touch Cover from attaching to the bottom bezel.
It apparently does; I'm ordering my TypeCover from Amazon (since I have a lot of Amazon credits) so I can't demonstrate it yet, but if you go to the link I posted, it shows a picture of it.
EDIT: Unless you mean the feature where you can prop the keyboard up at an angle; then yeah, it definitely won't work.
The keyboard sticking to the screen the way it does, IMO, is nothing more than a gimmick, and is actually NOT good for your wrists. I use mine flat unless I'm in a place where I need that extra inch (almost) of space.
More info for the curious:
http://forums.windowscentral.com/microsoft-surface-pro-3/285065-2.htm#post2632332
