Hey guys!
Has any one tried using bluetooth headphones with the Surface Pro 3? I have the motorola S10-HD, which I use with my Venue Pro 8, Cellphone, Surface RT, and they work perfectly.
When using them with the Surface Pro 3 they just connect for a few seconds then disconnect, then reconnect over and over, some very limited times got them to work and play music. Most of the time they wont work tho.
Any idea or any possible solution? This is my 2nd Surface Pro 3, and in both of them had the same issue.
Thanks,
J
Thanks,
J
