So today I was doing a battery drain test, I switched to firefox instead of chrome for it. In two hours (19:45 - 21:45) whilst using 15 firefox tabs, onenote, about 30 minutes worth of debugging in VS professional, skype, hexchat, outlook 2013 and some metro apps in the background, I'm down to 58%.
That means that continuing with my current usage I would get 4 hours in total, which is 5 less than microsoft claims.
2. The kickstand works fine, but I find it a bit stiffer to get to 22 degrees than the Surface RT, also when it is between 22 degrees and 150 degrees, I can shake the kickstand and it wobbles a lot but doesnt move because of the friction hinge. Also at some angles when I put it down on a surface like my bed or lap the kickstand moves slightly
09-10-2014 03:48 PM
