1. Dadstar0410's Avatar
    I was cleaning my Type Cover tonight, and I did a bad thing. I put the Cover under the sink. I figured I would water the bezel of the keyboard, and I would use my towel to spread the water around. Well, what I discovered after I turned the sink off was that water was seeping between the keys and below to what I think is the circuitry (whatever is directly under the keys). Now when I try to use it, some keys register two letters, and the trackpad about 60% of the time fails to work. I know I made a huge mistake,but it hasn't been very long since it happened. I'm wondering if there's a way to get it back to the way it was before.
    02-27-2015 12:11 AM
  2. anon8959613's Avatar
    Use a hair dryer.
    And FYI People don't turn ON electronic devices after they have been wet with water.
    Impure water is a good conductor and while you turn it on you may short circuit the entire thing.
    02-27-2015 01:53 AM
  3. Dadstar0410's Avatar
    Use a hair dryer.
    How wilI I know if it works then? And how long must I keep it under the hair dryer?
    02-27-2015 06:49 PM
  4. anon8959613's Avatar
    Better take it to where you can fix it.
    It needs to be opened and serviced to make sure no moisture remains.
    02-27-2015 07:15 PM
  5. Bolimomo's Avatar
    It may be more costly to take it to a repair shop for repair, considering your time, their time, and their labor rate, which could be up to $100/hour? A new type cover is only $129.
    02-27-2015 07:18 PM
  6. anon8959613's Avatar
    The water went inside his device !
    What else is the option ?
    ​He shouldnt open it by himself If its still under warranty.
    02-27-2015 07:25 PM
  7. Aaron Yawn's Avatar
    One idea would be to but large bag of rice and a big bag to put both cover and rice in for a couple of days
    anon8959613 and anon(7901790) like this.
    02-27-2015 07:50 PM
  8. Dadstar0410's Avatar
    I had to return it. Nothing worked. Liquid damage isn't covered by warranty either! Of course not. $129.00 to replace 😒
    02-28-2015 07:25 PM
  1. How to edit full resolution photos in 1520?
    By vestasan in forum Ask a Question
    Last Post: 06-28-2015, 11:04 AM
  2. Reversing from Windows Developer back to AT&T
    By mbranscum in forum Other Operating Systems
    Last Post: 03-17-2015, 08:45 PM
  3. Wireless charging plate breaks the magnetic sensor in Lumia 1020?
    By nickisverygood in forum Windows Phones
    Last Post: 03-04-2015, 06:06 PM
  4. Denim update available for 1520 in India
    By rajamass in forum Windows Phones
    Last Post: 02-27-2015, 12:51 AM
  5. How do I connect my phone to my computer?
    Last Post: 02-26-2015, 11:02 PM
