Trident Cyclops vs Urban Armor Gear Surface Pro cases: which case to buy?
BGrewer
276
I'm thinking of getting a case for my Surface Pro 3 and was wondering which case is better: the Trident Cyclops or UAG Scout/Rogue?
The specs. I'm inquiring about:
-If the case is easy to remove, as I don't want to use it all the time - the only time I will be using it is in the field or when i'm out and about.
-Degree of protection it/they offer
-If the case is water resistant (or waterproof) to an extent
-How much bulk does it add to the tablet
-Can it be used with the keyboard cover
-Is 'x case' worth the money
-Is touch screen performance reduced? (I think this only applies to the Trident case)
-Has it survived a drop?
Also, does anyone have a case which is better than these two?
quicktravo
