1. BGrewer's Avatar
    Does anyone know if there is a lock (like Kingstons) for the Pro 3?
    05-25-2015 09:52 AM
  2. xandros9's Avatar
    05-25-2015 10:00 AM
  3. BGrewer's Avatar
    I was looking for an alternative, as Kensington locks are only available for the dock, not the tablet itself.
    05-25-2015 10:07 AM
  4. xandros9's Avatar
    Maybe there's a case that has that feature?
    Or maybe one can Mac-gyver a solution
    05-25-2015 10:15 AM
  5. BGrewer's Avatar
    I've looked at cases and sadly there aren't any practical cases, the only ones available are to turn your surface into a cash point (to use with PayPal)
    The only Mac-Gyver esk solution there is is to drill a hole through the kickstand to attach a lock but I don't fancy doing that.
    xandros9 likes this.
    05-25-2015 12:37 PM
  6. kenjancef's Avatar
    I had asked this question a few months ago... the only feature I need that is missing. I shoot sports, and use the Surface as my mobile editing rig. I get scared leaving it in the Media Room or press box while I'm out shooting. I'm almost thinking about the hole in the stand thing, as long as it looks neat. Might be the only choice...
    05-25-2015 10:25 PM
  7. the whole taco's Avatar
    rather than drilling a hole you could cut a slot in the kickstand to take the lock.
    haven't tried that myself cause mine is usually in the dock and the kickstand isn't visible then
    05-25-2015 11:21 PM
  8. the whole taco's Avatar
    actually there are locks that have a base plate that can either be glued or suction-capped to the pro
    search 'Kensington lock'
    05-26-2015 03:05 AM
  1. Surface Pro 2 and Samsung Plasma TV as a monitor
    By Daniel Tyrrell in forum Microsoft Surface Pro
    Last Post: 05-25-2015, 06:39 PM
  2. Windows hello and surface pro 3
    By Paul Foulkes in forum Ask a Question
    Last Post: 05-25-2015, 06:09 AM
  3. How can I turn off Lumia 535 screen lock unlock sound?
    Last Post: 05-25-2015, 02:10 AM
  4. Replies: 2
    Last Post: 05-24-2015, 08:31 AM
  5. How can I improve battery life on Surface Pro 3?
    By Windows Central Question in forum Microsoft Surface Pro
    Last Post: 05-23-2015, 11:13 PM
