Is Edge what has been killing my SP3 battery?
Talldog
134
Since the latest round of updates, I've noticed that battery life has been a little better, but it's inconsistent and frequently still pretty bad (losing >20%/hr just web browsing). Two days ago, I had 3 Edge tabs open browsing a few sites (including this one) and I noticed my Surface was hot and the fan was going for no apparent reason. I started Task Manager and saw that Edge was using 25% CPU. Since then I've been using IE when I'm on battery power, and it's made a big improvement in my battery life. It's not hot, and the fan isn't on. Not sure why (lack of ad blocker, maybe?) but there you go.
Witness
454
Not sure, but whatever it is, I really want to go back to 8.1 now. Between OneDrive's missing placeholder, power drain, crappy Photo app and wonky little graphical issues it's kind of a bust on the SP3. The only thing that's holding me back is that I don't have time to go through the process.
homeedition88
35
Yes it kills and for a reason. One of them is because no ad block. Ads especially with flash based, stole your cpu power. It is a new browser and have got a lot of bugs. Hangs and recovering tabs consume a lot of CPU power. But still for power consumption it is as good as chrome (which is very power hungry browser)
Talldog
134
It could very well be a memory leak too. Next time it happens see if you can notice how much memory its consuming.
I just fired up Edge and opened 3 tabs. Within a few minutes, my Surface was getting hot with CPU between 25 and 50% and memory over 2Gb. Shut down Edge and it cooled off quickly.
Wes Smith
88
damn that doesn't sound good. I tried on mine the same thing and cant replicate. suspect it might be certain websites that its getting stuck in a loop and cranking up that high cpu and mem usage.
MBSMD
61
Edge sucks. Few features and is a battery killer. Fans ramp up on my SP3/i5.
Chrome has all necessary features, but is also a processor hog.
Firefox seems lean on the processor. Fans don't ramp up like with MS Edge. UI is too small to be touch comfortable though and the on-screen keyboard doesn't pop up on its own.
Hate to say it, but my iPad is a better web browsing device.
Michael Alan Goff
1,073
Firefox nightly fixes the keyboard issue you're having. The scrolling is pretty bad, though.
Engineers
5
This^. I was wondering if this was just happening to me. About 10 minutes after turning on my SP3, the system is using most of the available memory. And this happens all the time. It is even worse when I use Edge. But even if I don't use Edge my fans are running fast and hot. Battery life sucks. I basically can't run my SP3 for more than 1 hour without restarting because the system is using so much memory and every thing gets slow and I have windows poping up saying my memory is low. Basically W10 made my SP3 unusable.
I've been trying to get info on this but every time I ask the question I get bashed as a Microsoft hater from all the fanboys that claim W10 is great.
Carnes
