Also, here is the battery life info.
https://forums.windowscentral.com/e...surface-pro-4%23techspec-block&token=n1GWJ4wY
If you read the fine print it says this about which CPU they get the 9 hours battery life rating from and how they got it.
"2 Testing conducted by Microsoft in September 2015 using preproduction Intel? Core? i5, 256GB, 8 GB RAM device. Testing consisted of full battery discharge during video playback. All settings were default except: Wi-Fi was associated with a network. Battery life varies significantly with settings, usage, and other factors."
This leads me to believe that realistically if you are using it beyond light duty you'll probably get in the 6-7 hours range. Maybe 8 if you dim the screen.
I am sure it can probably pull a full 9 hours in light duty usage though.
